Single Cable AC/DC Question
P
PandamaJ
I've got a 1.5 square mm four-cable. Could I potentially use just two wires at 230 volts in single-phase AC. And then could I potentially use the other two wires at 12V DC. This would be over a distance of 90 to 100 meters.
Do you foresee any problems occurring because of these parameters?
L
Loganellsworth3419
Could you specify a load power?
But, just approximating, a high voltage and an extra-low voltage mixed in the same cable wouldn't be the safest.
Hello.
You should check the voltage drop for the various voltages and loads against the cross-sectional area and distance. An easy and effective way to measure those parameters.
J
JasonJones13
You could always use a voltage drop set of calculations. Or just search for a voltage drop calculator.
You will need the complete lenght of the cable to calculate the voltage drop.
The following page takes that in measure:
Bertus
Please note -
they specify a one-way voltage drop, so need to multiply the result by two.
You will need the wire diameter, rather than the cross-sectional area.
V General Power Chat 1
S Power Management 4
