Not an answer but a note of possible consideration (not having much detail): isn't it preferable to use a constant current source, such as 20mA for example, instead of a constant voltage source to which you add a variable limiting resistor itself dependent on the voltage at the LED?Could someone please advise me on what type of variable resistor I should use for me to test and design LED fixtures. If you already know a good unit, please let me know the make and model of the unit. Thanks in advance for your input.
Thank you for your input. I will consider using a constant current driver.Not an answer but a note of possible consideration (not having much detail): isn't it preferable to use a constant current source, such as 20mA for example, instead of a constant voltage source to which you add a variable limiting resistor itself dependent on the voltage at the LED?
| Thread starter | Similar threads | Forum | Replies | Date |
Variable DC supply 2000V @ 0.75Amps | Batteries & Power Supply Design | 0 | |
| C | 0-24volt DC variable resistor | General Power Chat | 1 | |
| F | Variable Frequency Drive | General Power Chat | 4 | |
| D | Variable input, adjustable output DC DC conversion | Power Conversion | 4 | |
| S | Converting Variable AC Power Supply to 90 to 130VAC | Power Conversion | 3 |
