G
Hello!
I'm working on a project that includes an rtc,mcu and a display on a ~20mmx20mm pcb. I was thinking about not using a backup battery for my rtc (because the pcb is small) and came up with a circuit like this:
https://postimg.org/image/4byja31yp/
The main concept is that when usb (micro-usb) 5V is NOT connected the P type mosfet is open and the battery feeds into the regulator of 2.5V and powers all the components.
When the usb 5V IS connected the P type mosfet is closed and the battery gets charged, but at the same time my electronics get powered of of 5V microusb.
My question is:
1) Is this a good solution, is there a better solution that will not hurt the bank?
2)Will my electronics, mainly the RTC reset while the P type mosfet switches it's condition?
Also another idea I had is not connecting the 5V directly on the electronics. I was thinking about connecting the battery and the 5V to the regulator that goes to the electronics, so I don't have voltage up's and down's. I would connect the 5V to the + terminal of the regulator and the mosfet would stay the same.
Also I didn't pay attention and I drew a transistor, it should be a mosfet (dmp1045u).
Thank you for the upcoming replies!
My question is:
