Does outer voltage control loop affect the inner current control loop?
Hi everyone,
I am designing an average-current control boost converter as a learning example. I am at the point where I would like to desing the current compensator for the current loop. To get the converter into the correct operating point, I use a slow voltage loop, which sets the reference current to the current loop. However as soon as I connect this voltage loop, my current loop measurement changes significantly.
Here is a picture of my current loop measurements.
The gain labelled "With voltage loop" is the current loop gain I measure when I connect the voltage loop.
The gain labelled "Manually fixed current reference" is the current loop gain I measure, when i dont have a voltage loop, and I manually set the correct current reference as to achive the desired operating point.
I measure the current loop gain by stimulating the output of the current compensator.
Does anybody have an idea what is going on? I always thougth that I can measure the current loop gain independently from the voltage loop.
Thank you all for your help.
Regards,
Samo
The gain of the current loop in a boost is dependent on the pulse width. It is not a fixed value. When your voltage loop is switched on, the operating point, and thus the pulse width changes. This may be why you see a difference.
tmachinchnev General Power Chat 5
