Capacitor bank charging
Hi,
I am trying to build a capacitor charging circuit using a 24V battery. The supercapacitors are connected in series, and the capacitor bank needs to be charged up to 90V
I traced a circuit from a PCB, but I couldn’t complete the tracing as it is a 4-layer PCB, and I need to return it without causing any damage. The MOSFETs used in the circuit are rated at 60V, 75A.
I attempted to design a push-pull topology using 700V MOSFETs, but I encountered excessive drain-to-source voltage spikes, even after implementing a large RC snubber network.
Could someone help complete the circuit and explain its working? That would be extremely helpful.
Thank you!
