Metalized Polypropylene Capacitor replacement
Dear Experts
Greetings of the day!
Need to know the importance of replacing the Capacitors (Metalized Polypropylene Capacitors ) on sine wave application mainly on Motor run. To be more specific those capacitors that are used in the Output filter of the PWM circuit as low pass filters.
Yes -- if those metallized polypropylene (MPP) caps sit in the PWM inverter’s output low-pass (“sine-wave”) filter, keeping them healthy (and replacing when degraded) is important for motor life, EMI compliance, and drive reliability.
Why it matters
  • They carry high RMS ripple at the switching harmonics plus the fundamental reactive current. As ESR rises or C drops, the filter stops doing its job → higher THD on the motor, extra heating, audible whine, and possible drive trips.
  • MPP is self-healing: each clearing event slightly reduces electrode area, so capacitance drifts down over time. Excess dv/dt, overvoltage spikes, and heat accelerate this.
  • Thermal stress from ripple current raises core temperature; life roughly halves for every ~10 °C hotter operation.
How to judge health (condition-based, not calendar-based)
  1. Capacitance: measure at 1 kHz (or as per datasheet). If ΔC ≤ −5…−10% vs. nameplate or commissioning value, treat as suspect; >10–15% drop → replace.
  2. ESR / tan δ at a few kHz: ≥2× original is a red flag.
  3. Temperature rise: with worst-case load, if case ΔT consistently >10–15 °C over ambient, review sizing/placement or replace.
  4. Symptoms: rising output voltage/current THD, more acoustic noise, hotter motor, nuisance overcurrent/earth-fault trips, or EMI margin loss.
When (and what) to replace with
  • If these are motor-run caps rated only for 50/60 Hz sinusoidal current, they’re often not ideal for PWM ripple. For sine-wave/dv/dt filters, use AC-rated MKP “inverter output/sine-wave filter” capacitors with published:
    • Irms at your switching frequency band,
    • Low ESR/ESL,
    • dv/dt / pulse capability,
    • Ambient/Case temp rating (85–105 °C),
    • Climatic category and self-healing segmented metallization.
  • Size with 20–30% thermal and Irms headroom at worst-case: DC bus max, longest motor cable, highest ambient. Verify Irms(measured) < Irms(rated) and ΔT is acceptable.
Good practice
  • Annual checks: C, ESR/tan δ, and IR (insulation resistance) under comparable conditions; thermal scan under full load.
  • Keep leads short, ensure ventilation, avoid mounting next to hot inductors, and add/verify bleeder resistors and discharge procedures.
  • If you share part numbers, Vac/Vdc, C value, fsw, Irms, folks can sanity-check ratings and margins.
Bottom line: Replacing aging MPP caps in the inverter output filter is preventative maintenance that preserves the sine quality, reduces motor stress, and protects the drive—especially if the originals weren’t specified for PWM ripple.
