In remote networking projects, it is easy to misuse the reverse connection of the power supply. However, the reverse polarity of the power supply will usually cause the back-end capacitor to explode or the chip to burn, resulting in irreversible consequences.
To prevent a reverse connection of a power supply, you can use a diode, a fuse, or a polarized connector. A diode allows current to flow in only one direction, while a fuse will blow if too much current flows in the reverse direction. A polarized connector ensures that the power supply can only be connected in the correct orientation. Additionally, it is crucial to ensure that the power supply is appropriately labeled with the correct polarity and to always verify the correct orientation before making a connection.
