Hello all,
I've been working on a self powered device that uses a Raspberry Pi for its "brain".
because of the way the Pi is designed, I need a power management circuit that will interrupt the Pi's power supply after it has gone through an orderly shut-down. Normally, the Pi receives its power through a buck supply that's driven directly off a generator but a set of ultracapacitors takes over when the generator isn't active. When this is the case, the Pi runs some event dependent script for a timed shut-down after an elapsed time. Unfortunately, rebooting the Pi when it's in standby requires some operator interface unless the power has been completely interrupted so I've hacked up this circuit to disconnect the Pi from the capacitor bank at some interval following the shut-down sequence.
Can anyone see any potential problems with this approach?
I'm planning on using some LL FETs that I have laying around. The power requirements are minimal (< 15 watts).
I forgot to draw in the drain resistor for the first FET's gate (10kΩ to ground) and figured on tinkering with the unmarked capacitor and resistor values to get the delay I need: It will probably need to be around three to five seconds. The zener's just for the sake of my paranoia. Will this work?
Oh yeah, I almost forgot: The 5V output of the power converter is the power feed for the Pi.
Thanks,
Thanks,
