I planing to use an INA146 precision difference amplifier to do voltage level conversion from 0-12v to 0-3.3volt.
Since the input should be possible to change I like to add voltage follower on the input of the INA146.
My question is what kind of OP-amp should I select that are not damage the performance of the INA146. I guess that it is important that I use device with dual op:s so they are as equal as possible.
What other parameter should I lock at when I select the OP:s. (Gain, Offset, ...). Need to keep the cost down as much as possible but the performance of the INA146 should not be ruined.
Note:
I planning to power the INA146 with a +-15v supply (or may be +-12v).
Has any one added a capacitor to INA146 and created a 2:nd order LP-filter. If that is the case, should the cut of frequency be set to the same for the first and second stage? There is an example for AD628 that do this.
Note:
