AC voltage meter
Asharf ti
So, I'm trying to quantify the power consumption of one of my AC devices. My measurements, however, are not what I expected and/ or varying more than I expected.
I don't think I can fit a transformer in my lineup of devices. What do you think I could be using to get more accurate measurements?
Thank. Greatly appreciate your feedback.
What kind of power you need to measure - active (real), reactive, apparent ? Easiest and most reliable way is to use solution that is used in E-Meters (AFE) - it can fullfill most reqiuirements. Hope 0.1% accuracy is OK (if you can calibrate it once).
T
Tobiasfischer1
Were you thinking a linear optocoupler? That would work well, if @Asharf has room for a power supply in the mix?
